Enables a port.
| port_list | Specifies one or more ports or slots and ports. |
| all | Specifies all ports on the switch. |
All ports are enabled.
Use this command to enable the port(s) if you disabled the port(s) for security, administration, or troubleshooting purposes.
The following command enables ports 3, 5, and 12 through 15 on the stand-alone switch:
enable ports 3,5,12-15
The following command enables ports 3, 5, and 12 through 15 on the switch:
enable port 3,5,12-15
